Old 09-20-2015, 06:59 AM   #4
Gilles
What year is the car, and where did you source the replacement bearings from?
Hello JFP, the car It's an '07 Cayman S and bought the bearings from Pelican.
After reading your post ran to the garage where I kept one of the OEM bearing races that I removed and it's identical to the ones for the front wheels (also from Pelican) that I have not installed yet.
Note: After damaging one of the new ones on the rear (famous wrong moves..) I installed one that I found at the local NAPA (which I order by year & model) and it is the same bearing as the ones I got from Pelican (FAG P/N 805394C)
JFP, do you know if both of the rear speed sensors are connected into the same harness that somehow had a connector that got disturbed? Because once I installed the drive shafts but before installing the support braces and triangle I cleaned the passenger side suspension area because had a lot of nasty grim due to a previous AOS failure.
and on the base of the frame (where the suspension components and the braces attach) there was a fairly large connector that I covered with a plastic bag before spraying the surrounding area with engine degreaser, I was careful but if this is the only connector that I got close to during the bearing replacement…
I hope that I don't have to take the car to the dealer :-(
Thank you in advance for your comments!
Gilles is offline   Reply With Quote
