Old 09-19-2015, 05:31 PM   #2
KevinH1990
KevinH1990's Avatar
I have a 2000 with just over 100k on it and the car you are considering is similar to mine.
I retrofitted the heated seats and litronic headlights to my car and I think they are desirable options. It appears that you have the memory seats as well.
I think the major drawback of the car is that it has a plastic rear window in the top. I have installed a top and frame from a 2004 Boxster and it makes a big difference.
Although no one can be certain, there is at least a strong likelihood that the engine has a dual row IMS. Those will fail, but they are less likely to do so than the later cars with the single-row bearing.
It sounds like a good car and if I was in the market I would pay $10,500 for it. I would plan on upgrading the top at some point and set aside some money for the water pump, clutch, flywheel and rear-wheel bearings. I have appended a list at the bottom of this post of the repairs and maintenance I have performed on my car which I purchased with 30k miles on it. I put the mileage and cost next to the item that needed to be done. I do some work myself, and saved some labor over the years. Based on my experience, you could have about 30k miles before you encounter major expenses.
Air Filter 31,120 $23.08
Cabin Filter 31,120 $13.72
Oil Change 34,188
Replace oil filler tube 39,006 $190.25
Replace hinge $25.31
Oil Change 43,392
4 Sumitomo HTR Z3 Tires 51,609 $377.80
Tire Installation 51,609 $114.70
Oil Change 49,360
Brake Flush 52,023 $135.91
Front trunk microswitch $47.63
Oil Change 55,795
Serpentine Belt 60,498
Air Filter 60,948
Spark plugs changed 61,726
Cabin Filter 62,200
Oil Change 65,317
Replaced spark plug tube 65,317
Front brake pads and sensors 65,436 $124.50
Oil Change 71,767
Oil Change 80,269
2 Sumitomo HTR Z III $232.60
Tire Installation 83,364 $45.00
Water pump and coolant 84,612 $406.45
Oil Change 87,546
Clutch kit and pilot bearing 91,404 $744.53
Dual mass flywheel with bolt kit 91,404 $1,036.03
Air Oil Separator with tube 91,404 $121.34
Oil line assembly 91,404 $68.14
Rear Main Seal 91,404 $26.50
PP Bolts 91,404 $5.52
Oil Change 91,404 $56.00
Transmission oil change 91,404 $21.32
Labor for 8 previous items 91,404 $1,089.00
Cabin Filter 91,470
Air Filter 91,743
Replace rear wheel bearings 94,364 $750.43
Battery 97,363 $140.00
Spark plugs changed 97,370
Spark plug tube - driver's side rear 97,370
Wiper Blades 97,800 $14.10
Oil Pressure Sensor 98,805 $62.77
Oil Leak Repair 100,079 $245.65
Oil Change 100,205
