Old 09-17-2015, 02:23 PM   #14
Deadeye
Originally Posted by jaykay View Post
Nice glad someone has actually done this....seems to be the best packaging solution. Were you able to incorporate the intake right in the existing side vent rubber plastic duct for an ultra OEM look? You would also get a boost effect with the fan when it runs. Don't know how the heck you mounted the heat xcr though...my imagination / vis skills can't picture that...I would guess an edge is facing up..so get air flow. Do you have a manual fan switch?
I take it that cooling the trans take care of everything else including engine oil. Any data?
Pictures would be much appreciated!
The car is loaded into the trailer for a trip to the track this weekend. When I get back I will get it on the lift and take some pics. I use some of the same components in the Patrick kit and I added a small fan to pull the cold air coming in from the right side engine compartment vent through the cooler. Fan is switched to come on with the pump through a separate relay. Trans oil temps with back to back drivers (wifey drives it as well) get up to 260 degrees. Just had a full rebuild on the box partially due to hot temps (and 5 years of track abuse)
Deadeye is offline   Reply With Quote
