Old 09-17-2015, 01:19 PM   #2
BYprodriver
BYprodriver's Avatar
Does anyone know the approximate weight on the front and rear tires on a stock Boxster S?
Not the max load as listed in the owners manual, but actual weight.
I know my it won't be exact for my car, but it will be close enough for govt. work
I trying to figure out some track tire pressure recommendations using a formula that uses front and back weight
My 2000 S manual is 2855 lbs from factory, your 2004 is probably 75 lbs more. Find front to rear weight bias & figure from there. Does the formula consider tire size?
