Old 09-16-2015, 08:25 PM   #1
ftp19601960
clamshell does not close one side
One side of my clamshell is a little bit loose and does not lock completely on closed state (comparing to another side). I checked V lever and it’s identical both sides. “bad” side edge sits a little bit higher than good one. I think as “closed” lid position corresponds to two different V lever rotations it has to be either V lever transmission axis offset or some bad (weak spring?) rod. Eccentric bolt has almost zero effect on the situations. It fills like in both roof up and roof down scenarios there is not enough tension on “bad” side to hold lid down.
ftp19601960 is offline   Reply With Quote
