Old 09-16-2015, 03:44 PM   #20
DennisAN
DennisAN's Avatar
Flywheel bolts are torqued to 19 ft. lb. plus 120 degrees.
It's hard to measure 120 degrees while lying under the car on jackstands. I used my HF 1/2" torque wrench as a ratchet. Spin your ratchet 180 degrees and count how many clicks it takes. Then mult by 2/3. You can then tighten the bolts that number of clicks but not necessarily at the same time. You can swing the ratchet fewer clicks counting up how far back you drop the ratchet.
You also should have some "LONG" Allen sockets to remove and later torque the Allen bolts that connect the stub axles to the tranny.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
