Old 09-16-2015, 02:43 PM   #13
jaykay
jaykay's Avatar
Originally Posted by Deadeye View Post
I have installed an oil cooler as described above into my track car to keep the trans oil temps under control. I ran a 3" flexible brake duct from the right side vent scoop to a small heat exchanger with a 5" Spal fan attached. It is mounted directly to the rear trunk floor in a small space next to the gearbox on passenger side. I will post pics when I get the car back on the lift.
Nice glad someone has actually done this....seems to be the best packaging solution. Were you able to incorporate the intake right in the existing side vent rubber plastic duct for an ultra OEM look? You would also get a boost effect with the fan when it runs. Don't know how the heck you mounted the heat xcr though...my imagination / vis skills can't picture that...I would guess an edge is facing up..so get air flow. Do you have a manual fan switch?
I take it that cooling the trans take care of everything else including engine oil. Any data?
Pictures would be much appreciated!
986 00S
