Old 09-16-2015, 11:36 AM   #1
Gilles
Originally Posted by lkchris View Post
I think it safe to assume Boxster cooling was thoroughly tested by Porsche.
Good to understand that a sustained high-speed Autobahn run will get the engine hotter than any other sort of use. Basically, it's more fuel burned equals more heat. Not a lot of heat generated idling, but plenty generated at sustained high rpms. Electric fans are lots better than the attached-to-the-water-pump fans of old mericun iron---where the fan runs at idle speed, too. Apples and oranges.
I believe that burning fuel, actually helps to keep the engine cooler, and a lean mixture will quickly overheat an engine (and put a hole on your piston..), this is a well known fact on aviation engines
Also believe that be cruising at top speed is much better for the engine than sitting in a traffic jam on the middle of the summer with the AC on and without proper airflow.
However, this conclusions are from my own observations and I am no an engine expert by any means...
