Old 09-16-2015, 09:33 AM   #23
lkchris
lkchris's Avatar
I think it safe to assume Boxster cooling was thoroughly tested by Porsche.
Good to understand that a sustained high-speed Autobahn run will get the engine hotter than any other sort of use. Basically, it's more fuel burned equals more heat. Not a lot of heat generated idling, but plenty generated at sustained high rpms. Electric fans are lots better than the attached-to-the-water-pump fans of old mericun iron---where the fan runs at idle speed, too. Apples and oranges.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
