Originally Posted by 2speed
I tell you what I do not care for is removing the TB . I have dropped the studs several times trying to get that bottom right one out .
Take the air intake loose, remove the brace bolt at the bottom of the TB, loosen the two c clamps on the air plenums and rotate the TB upwards to access whatever you need to access. I might be making this too simple.
