It's got gutted CF doors, CF fenders, front bumper cover and both hoods. Hard top is fiber glass. All AC components are removed. Wiring harness is stripped. I did not replace the tank. The only other items I can think of to lose more weight are:
- radiator fans still installed, could be removed
- wipers still installed, easily removed
c- ross bar in cabin could be cut (assuming the cage provides sufficient stiffness)
- Techart tail mounted above OEM tail could be removed
- upgraded (big red) brakes replaced by OEM brakes
- smaller gains could be had by replacing engine covers, seat etc with lighter CF versions but that's pretty pricey
- passenger side seat pan could be removed, cheap but fairly time consuming
- standard dash could be replaced by AIM or similar
