Originally Posted by PaulDash
Have the same problem. Durametric says lock sensors in frunk and trunk, both doors, and central console lid work fine. Still, I get the chirp.
It started when I put in an aftermarket Becker radio. Its alarm light flashes when car is locked, but could it be the little cable in the back needs to be grounded (or at +12V)?
There is a ground wire that is attached on the left side of the frame that the radio slides into. Disconnect this wire and you should be good.
Take a look at the right side of the below photo. You will see where the ground wire is attached.
Originally Posted by JRide
I just learned something new. Didn't know the center console lid locks with the remote!
And... it locks the gas lid also.
