Originally Posted by 78F350
It looks like JayG will get you on the right track.
Here's some stuff you may want to look at to help you understand:
The water pump replacement process:
The video suggested pressure washing the radiator and condenser. If you go that route back way off and be careful with the water spray. The high pressure can bend the fins on the radiator and condenser closing the airflow path through them.
