Old 09-11-2015, 01:31 PM   #1
DarkStar
DarkStar's Avatar
Soo much I could say. So little time. I'm a heavy audiophile. The factory speakers are just pure junk. Upgrading them is worth it on so many levels. My entire factory amp system has been removed and the wires we're re wired into a new legit amp. It's not hard to locate speaker wires usually car manufactures twist speaker wires together in pair. To locate which speaker this is you can use a test meter with a negative/positive switch to apply power or you can use a battery to pop the speakers. Then label them. I'd stay away from using the internal amp of the radio unless you don't care for quality like others do. Unless your trying out the new Sony deck that has a legit class d 4 channel amp built into it. I went the route of 5v preamp outputs with a DSP that has 10v outputs.
Sent from my SM-G925T using Tapatalk
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
