Thread: Soft Top Repair
Old 09-08-2015, 07:56 AM   #1
Rob175
Rob175's Avatar
Soft Top Repair
I noticed recently that my soft top is no longer as "taught" as it was a few weeks ago. After some investigation I discovered that the "glued" or "heat welded" fabric which is attached to the middle and rear soft top support bars and provides for the proper folding and tension of the fabric had become "unattached".
After calling numerous specialists (and being told the ONLY solution was to install a new top) I used 1/4" wide, 3M VHB (very high bond) double sided foam tape. After allowing 4 days to cure, it appears all is good. It might not hold for years, but then again I seldom raise or lower the top more than 2 or 3 times a year (summer-sunny weather car only).
A lot less $$ than a new top w/install.
Rob175 is online now   Reply With Quote
