Old 09-08-2015, 05:06 AM   #14
Carlisabadman986
Carlisabadman986's Avatar
Originally Posted by koosh View Post
well i had a go on saturday afetrnoon. got the dremel out and cut the bolt. instead of cutting a slot and screwing it out (which i couldnt do due to not having enough room for a screwdriver), i cut from top to bottom and took the head of the bolt clean off. the coil slipped over the shank of the bolt, then the left over shank just finger screwed out! took all of 10 minutes! replaced with shiny new stainless bolts although i cant see me needing to ever remove them again!
This is what I am going to have to do.
As of now I just put everything back and have put about 1k miles without a misfire.
01 Base Arctic Silver, Top Speed Muffler and Cat Delete pipes, Ben006 Short shifter
Carlisabadman986 is offline   Reply With Quote
