well i had a go on saturday afetrnoon. got the dremel out and cut the bolt. instead of cutting a slot and screwing it out (which i couldnt do due to not having enough room for a screwdriver), i cut from top to bottom and took the head of the bolt clean off. the coil slipped over the shank of the bolt, then the left over shank just finger screwed out! took all of 10 minutes! replaced with shiny new stainless bolts although i cant see me needing to ever remove them again!
