Old 09-07-2015, 08:09 AM   #11
Gilles
Originally Posted by nieuwhzn View Post
Check if it is not coming from above the bell housing. In my case it was a failing aos apparently dumping enough oil in the inlet that it dripped down on the bell housing.
+ 1
I could swear that my valve cover was leaking when the AOS was the culprit.
The second time a couple of years later, the leak was caused by a crack on the lower accordion hose that connects the AOS with the crankcase vent valve...
