Old 09-07-2015, 08:15 AM   #1
ssmart
Boxster S 986 front anti roll bar/sway bar bushes replace
How easy is it to change the 2 front anti roll bar/sway bar bushes on the front of a 986 lying on your back with the car on axle stands.....is it just remove the 2 studs on either end and the bar falls enough to let you change out the bushes????
Also, any lubricants needed prior to fitting and where?
ssmart is offline   Reply With Quote
