Old 09-06-2015, 06:30 PM   #568
madmodz
madmodz's Avatar
Woody thanks for the help today. I was able to pull of the power steering lines off the steering column. At the rear connection, I got the large brass fitting off, but the smaller one 15mm was frozen closed. Using a flare nut wrench it still wouldn't come off and destroyed the brass fitting. So I got to get the smaller line going to the motor.
Can you identify the plastic lines in the green circle? Its a series of 4 lines coming from the front. 2 are metal, and two are plastic. One of the plastic lines has hole in it.
It has a quick connect fitting that you push the two tabs end to release the line. My guess is some kind of vent. Thanks ahead
madmodz is offline   Reply With Quote
