					Originally Posted by jaykay  I would have thought the difference in cost between between a 3.6 bore and 3.8, 4.0 would be minor compared to everything else and really attractive if you are doing the work yourself.  Working with 3.2 heads (five chain) I would have also thought 3.8, 4.0 would have bumped up the torque significantly with at least another 100Hp peak with nice drive ability. |
 You need a 3.6 crankshaft & carrier & rods & LN pistons. For anything more stressful than auto crossing I would insist upon aftermarket rods.  3.8+ will have LOTS of low rpm torque, enough to increase autocross times.Peak HP I would guess  would increase 8-12% depending on head work & bolt-on external parts.
				__________________OE engine rebuilt,3.6 litre LN Engineering billet sleeves,triple row IMSB,LN rods.  Deep sump oil pan with DT40 oil.
