Old 09-03-2015, 05:23 AM   #14
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by Crono0001 View Post
Button sometimes works, sometimes doesn't. Sometimes works and stops halfway. Sometimes hiccups, like a loose ground somewhere.
if your windows drop when you pull the handle then its probably not the microsiwtch in the center latch above the mirror.
is your emergency brake light on all the time while operating the top? does it flicker? the microswitch in it failing is pretty common and since its one of the requirements the top wont operate. as a temporary fix people pull on the handbrake a few times until the microswitch works and the light is on the dash.
you can replace the microswitch or get the smart top that you've been told about.
alternatively you can modify your existing top relay to ignore the speed sensor (just pull it out and bend a pin) and even the emergency brake being pulled (this second one is bit more tricky and involves soldering a wire inside the relay). you're getting sort of a halfway smart top because one of the best parts of that is you dont have to hold the button pressed all the time.
CrisZenithBlue is offline   Reply With Quote
