Originally Posted by tommy583
Defrost uses the ac to take away moisture at the same time it uses the heater core to blow warm air. If you take away the ac compressor then you will lose the moisture removal part, but if you leave the heater core you will still get warm air. It won't defrost as well without the ac part.
Thanks Tommy. Compressor getting deleted. Here is a hypothetical . . . running on a 60 degree morning, windows open, car is cold, full suit and helmet. Will the windshield 'fog' up? IF there is no AC compressor, is defrost just slow or totally nonfunctional?
