Old 08-31-2015, 12:18 PM   #11
911monty
911monty's Avatar
Originally Posted by 358Ron View Post
I'm having the same window problem on my 2003 Boxster S. Only on the passengers side. Just started this past weekend. I'm going to lower the window and raise it and hold for 5 seconds with door closed, ( as advised here), and see if this works. I can manually raise and lower the window at this time. It just doesn't jump down when I pull on the door handle like it did before. When I try to close the door the window is too high, for door to close. Does anybody have any other suggestions if this procedure I'm going to try doesn't work.
The procedure you are going to do is to initialize the windows such as after battery change. Do your windows attempt to drop using the inside or outside door handles? If not it may be the micro switch on the door handle.
