Visual aid. Each "U" shape is a pad sensor. Black circles are rotors. Anything that stops the voltage from returning to the cluster will trigger the brake wear light.
Example: absence of voltage at the right rear sensor does not mean that is where the problem lies. The problem sensor/wiring could be anywhere in the loop before that (front left or front right).
