It's $35 a gallon from Sunset Imports, versus $50 at most dealers. However, if you don't do a full flush you won't need as much. You will get about 3 gallons from the coolant drain plug (make sure to replace the crush washer), the other 2-3 gallons would require you to disconnect one of the heater core lines, and the lower radiator hoses (or you could jack the front of the car up higher than the rear as you drain it).
