Thread: audio help
Old 08-31-2015, 11:20 AM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
audio help
hi guys,
i got my hands on a stock bose subwoofer and am stuck trying to connect it to my aftermarket Kenwood KDC-BT555U.
this HU only has an RCA type output for subwoofer (wiring instructions here: http://s3.amazonaws.com/szmanuals/9c0003c5f238fbb1d754e68a566174ee) which i believe requires to go through an amp that i already removed when i replaced the factory Becker. there is no direct wire output like i have for the speakers.
is there no other way of connecting the subwoofer separately with no amp? i did some research but havent found any adapter and not even sure if it will work with no amp. my audio skills suck what can i say..
right now i wired it directly to a rear speaker output as an interim solution. HU has 50 watts which is plenty for the stock bose sub so i dont need more power or an amp, i just want to hook it up separately so i can adjust sub settings.
hoping for an easy answer
thanks in advance,
Cristian
CrisZenithBlue is offline   Reply With Quote
