Old 08-31-2015, 12:16 PM   #10
kk2002s
kk2002s's Avatar
Originally Posted by Paul View Post
See if you can push the window down manually the rest of the way. If so you need a new window regulator. I just replaced this on my 98 a few weeks ago.
+1
After opening the door, if you can push the window down the 1/2 inch it's suppose to drop , then it's a stretched regulator cable. There is a Temp Fix if you search or you need to replace the regulator. I put in a spacer in the cable stop and that lets my window drop about a 1/4 inch, just enough to allow the door to open and close
The radio thing, yes if you disconnect the battery, you need to enter in the radio code
Seal Grey
