Old 08-31-2015, 04:10 AM   #1
ppbon
ppbon's Avatar
From the description of symptoms ...
... the most obvious cause is a clogged flexible brake line.
Believe it or not, flexible brake lines are wear items.
Happy Boxstering
Pedro
Originally Posted by gonzojive View Post
I'm having two problems with my 2001 Boxster brakes:
1) .5 miles from home, the rear driver's side brake became stuck one night while driving. I made it home and smoke was coming from the pads.
2) After cleaning the rear driver's side brake caliper,* I began bleeding the brakes using a Motive pressure bleeder. I tried both rear passenger's side and rear driver's side, but with both of these, <20ml of fluid came out of the bleed nipples. I left the system attached and pressurized for 20mins and no additional liquid came out. This is unexpected
Any diagnostic advice much appreciated. Tomorrow I'll try a 2-person bleed to see if I'm able to get more fluid flow that way, and also try bleeding the front brakes.
*To diagnose 1, I disassembled, cleaned, and reassembled the caliper. There was no pitting, corrosion, or scoring on the pistons. All pistons came out by applying ~120PSI air pressure. There were no tears in the dust boots. I had planned to buy new pressure seals and dust boots, and probably still will, but I think the root cause may be an issue with the hydraulic connection because of (2).
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
