Hey JayG; Timco is right. Do the motor mount at the same time. It makes both jobs easier. You will need to have the front end higher than the rear to get the coolant to drain from the radiators. I did the pump, mount low temp stat and hoses. Took about 3 hours. Your hoses may be fine. mine had a wear spot on 1 from the lower tray, but were soft and pliable. I changed since they were 17 years old. I used an airlift, but it is not required.
Oh yes the coolant gushes out when you pull the hose. Also have ignition on and temp to full hot to drain heater core.
Reason: Add
