Old 08-30-2015, 08:56 PM   #549
particlewave
Tony, if Woody can't help you, I have a rear cover (both sides are the same) with those holes already drilled and one without the holes. Also, you can get similar retaining pins at most hardware stores. They won't look the same, but do the same job. They are usually in the section with the bins of nuts, bolts, screws, etc. in a similar bin.
Usually called "fender flare pins".
