Old 08-29-2015, 07:08 AM   #19
BruceH
BruceH's Avatar
I use traditional bulbs. My turn signal is the stealth silver, no obvious amber! I also wired the fog LED to the brake LED so that both come on. The problem is, the first press of the brake pedal yields the original brake lights. The second press will activate the original brake lights AND the fogs. I have tried everything that I can think of to get both to work on the first press all of the time but have been unable, so, I just live with it. Others have had the same problem. The lights work as they are supposed to, it is only if you want to modify the wiring and get both lights(fog and brake) to illuminate that you will be frustrated. The lights are excellent quality IMO and have held up well. No problems there.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
