Old 08-28-2015, 12:27 PM   #14
Giller
Giller's Avatar
Originally Posted by alm001 View Post
I must chime in to say skip the sub for a number of reasons;
1) There is no way it can effectively delivery bass to the cabin
2) That "2000watt" amp is more than likely less than 200 watts.
You can go ahead and TRY... but you will not like the results, and will have wasted your time.
Focus on getting what you can out of the door speakers.
False. You can effectively get base to the cabin. Not overwhelming BOOMING base - but a good base non-the-less. My old ride had the Bose surround system and had the sub mounted behind the seats where the cubby is. It delivered solid surround sound base. I can only imagine if you had hooked that up to a more effective amp, you would have some solid booms behind your head. The rear surround speakers also helped to fill the cabin with a nice sound.
