Old 08-28-2015, 07:42 AM   #11
BYprodriver
BYprodriver's Avatar
Originally Posted by Dr_P View Post
Hi All.
Am brand new to forum.
I recently took my 986-S model (2002) for its 30k service and my technician (retired Porsche Dealer mechanic from NY area) found some metal shavings (some, not a lot) along with one small bit of plastic and one small bit of metal in the oil (dropped lower sump pan).
I have/had read extensively on IMSB issues (here and elsewhere) and expected this at some point, but when I called the nearest dealer for a quotation, I was surprised to find they actually quoted a higher price for the LN Engineering retrofit than for a retrofit with authentic Porsche parts. Moreover, the warranty for LN is only 30-days (assuming it passes the pre-approval process), while Porsche offers 2-years and unlimited mileage. This just seemed odd to me, although a pleasant surprise. I see posts from Jack Raby, etc. everywhere, and numerous posts and links to Pelican Parts, Flat6innovations, etc., but almost nothing from anyone who has had a Porsche Authorized Dealer perform the work. Just curious if anyone has any thoughts/comments/information to share? Am I missing anything, or is this actually likely to be as good a deal as it sounds?
My local technician said everything else on my S-model looked beautiful (it's had regular oil changes every 3-4k miles since new, about once a year), and I wouldn't have known anything otherwise without his expertise (purrs like a kitten, runs like a beast), so I'm inclined to continue as planned, but just wanted to double-check my thinking, having seen nothing about Dealer servicing this item.
Thanks all,
- Dr. P
Your instincts are correct because the only IMSB available from Porsche is the last design that requires complete disassembly of the engine to install, due to it's larger diameter. LN engineering offeres 3 different retrofits for your 2002 engine all of which are superior to the Porsche OE IMSB. You should read LNs website for accurate info & post in general discussions thread for more feedback.
