Old 08-26-2015, 09:38 PM   #275
Oldporscheguy
Was at my mechanics shop on MOnday and watched a 2005 Boxster being towed away withe a IMS failure after only 28K miles. We just bought a 40K mile junk Boxster S with good engine and transmission to put into a 2000 S with a blown IMS failure engine. and we did the IMS bearing during the swap. Cost was $3800 for bearing, clutch and remove good engine and transmission from donor car and replace into the 2000.
We chose the LN Engineering ceramic bearing. If you don't do a proactive IMS replacement, make sure you change oil often and cut open the oil filter and look for Metal and plastic at each oil change.
Oldporscheguy is offline   Reply With Quote
