Old 05-15-2006, 02:01 AM   #5
TanDaMan99
System is installed. Took 2 strait days of hard work. Absolutly NOTHING fit into the stock locations. Every part had to be dremel, drilled, or customized in some way to fit. Nothing too hard but time consuming non-the-less. I also took lots of pictures that should be posted pretty soon.
The upgrades consist of:
5.25" Door and 1" Tweeter:
Infinity Kappa Perfects 5.1
100W RMS, 400W Peak
4 Ohms
4" Dash Speaker:
Infinity Kappa 42.7
50W RMS, 150W Peak
2 Ohms
4 Channel Amp:
ARC Audio 4150-XXK
80W RMSx 4 at 4 Ohms, 160W RMS x 4 at 2 Ohms
S/R Ratio 105db
The install was long and painfull, but now that its all in there its amazing. All the wires are soldered, wound, and hidden. Very clean. There were some crossed channels and it sounded disappointing at first, but after a rewire and some tunning the sound is better than anything I've heard. Totally worth it.
The stock head unit was kept because the owner, NickW4811, wanted to keep the stock look. That was maintained; besides the relativly large, somewhat heavy 4 channel amp on the floor of the front trunk the car maintains a perfectly clean, stock look. Looking forward to response after pictures are up of what we went through.
TanDaMan99 is offline   Reply With Quote
