Originally Posted by jdlmodelt
I would mount the CLU properly, might just be a bad ground connection. A bad ground causes all kinds of problems including blown fuses.
Mine is mounted properly, I believe that was the original poster and never mentioned if he found the problem. You are correct though about a bad ground causing problems. I'm just thankful my windows are working again without having to pull the door panels off.
