Old 08-24-2015, 08:47 AM   #1
flouese
flouese's Avatar
Shifting trouble in N. Florida
A 986 newbie, but long time owner of a 66 912...
Recently bought a 99 986 w/185K mi. Drove fine for a few minutes, then broke the hydraulic fluid line at the slave cylinder.
- Replaced the fluid line
- Bled the system using a pressure bleeder (both bleed valves on each brake caliper and the slave cylinder and made sure all old fluid was replaced w/new, & no bubbles were present
- Car shifts fine (smooth) in the driveway with the car not running
- Once turned on, in idle, it is difficult to engage 1st & reverse
- Down shifting from 2nd to 1st is difficult
- Had to turn the car off, put in reverse, restart the car to back into driveway
- While the car in sitting in the driveway, off, there is a sucking sound from the hydraulic fluid reservoir . I put a piece of plastic bag over the opening, put the cap back on, no more sucking.
I apologize for posting this issue here, since I posted in the DIY section. Very few responses in DIY. Hope more people see this post. Thanks in advance.
Fred in N. Florida
Any thought on my shifting issue?
flouese is offline   Reply With Quote
