Thread: Help please
Old 08-23-2015, 07:21 PM   #12
jdlmodelt
Originally Posted by Miata2Boxster View Post
I did a complete check for shorts and found none. When I unplug the CLU, C3 fuse does not blow. As soon as I plug back in the CLU C3 blows. The Jack a&& prior owner left the CLU unmounted and dangling....seems to not be original either. He must have got a used one and stuck his hand under the seat to make the switch.. When I opened it I found no apparent moisture or corrosion on the circuit board. I guess I will get another and see if it does the trick after installation.
Do I need to have a code to install if I don't use my remote locking function from my keys?
I would mount the CLU properly, might just be a bad ground connection. A bad ground causes all kinds of problems including blown fuses.
