Thread: V8 Conversion
Old 08-23-2015, 03:14 PM   #25
martsink
Starter Motor:
I picked up an $50 starter from a local scrap yard which came off a 2005 Silverado. The Kennedy Engineering adapter plate was designed around LS1 starter, so I had to make some modifications. The moulding in the dome is a little bigger I guess... I spent a good hour filing away, but eventually I got it to fit. The reason I got a truck starter over LS1 is because it's cheaper and I heard LS1 starters tend to crack.
Oil:
I didn't want to start the engine without priming it, so I purchased a drill pump at Princess Auto for $15. One end of the hose clamps onto the filter threads on the oil pan and the other into a jug of oil. This pump has no problems reaching 45 PSI. I stuck a gauge on my remote mount oil pressure switch hose (I will eventually post part numbers and pics for this part).
As for the tranny, I called Porsche about gear oil, which they quoted me at $55 a liter!!! I ended up purchasing some Swepco 201 which is manufactured locally, but surprisingly difficult to find.
Engine Cover:
The engine cover still fits, but it had to be cut a bit to make room for the throttlebody.
Rennline Floor Boards:
Rennline hooked me up with a wicked deal on their racing floor boards. I really didn't want to put carpet back in this car, so these things are great.
Corbeau Seats:
I also gotta thank Corbeau for hooking me up with a deal on these FX1 Pro seats and rails. My friend started working on the brackets the other day while I was making brake lines.
Cracked Rear Subframe:
I noticed a crack on the rear subframe side section where it mounts to the body. It seems like it was put together with a bent stud by the previous owner that caused it to crack. While taking it off, one of the lower control arm bolts got stuck inside the bushing and pretty much pulled it apart. This was a huge pain in the ass, but at least I got a sweet deal from Woody for the replacement.
Brakes:
Pretty much all the brakes lines are gone on this car. I tried making some hard lines out of the copper-nickel stuff, but had a hard time getting them to flare properly. I ended up buying some poly vinyl fluoride coated metal lines from NAPA. This stuff is great, they flare perfectly and are easy to bend. I would also recommend Lisle tube pliers if you plan on doing any kind of brake line work.
martsink is offline   Reply With Quote
