Old 08-23-2015, 12:18 PM   #1
jpc763
jpc763's Avatar
is the car level?
hot or cold?
if after driving, did you wait 5-10 min for it to drain back to the sump?
The car is level and it was level for the oil change.
The oil change was done with the car warm (not quite up to the normal op temperature)
I did not wait any time after the drive. I will check in 15 or so minutes.
Another note. My last oil change was with a local indy who installed the LN magnetic plug. I removed the plug and there was no crush washer unless it washed out of with the oil. I ran my finger in the drain hole and there is no washer. Wouldn't I have had a leak for the past 12 months if the plug was installed without a crush washer?
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
