Old 08-22-2015, 08:48 PM   #116
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by Swhitcomb View Post
Please forgive my ignorance and lack of having a schematic. How do I check for voltage on the positive side?
Actually you just check that negative signal wire for 12 volts or battery voltage when the alarm is on. Grounding that wire will lock or unlock the door.
In attempt to clarify, when the alarm is on check the negative signal wire, you should see battery voltage when it is not grounded. If there is no battery voltage, that is where your issue is. I think for whatever reason there's no power to the door locks when the alarm is on.
Sent from my SM-T310 using Tapatalk
