Old 08-22-2015, 08:24 PM   #11
particlewave
Still, if you can unlock it with the key in the door once armed, you should be able to do it remotely since the module is just closing the circuit, same as the key.
I'll have another look at the wiring diagram...there is one more wire to try.
When you unlock it at the door with the key, do you hear the lock/unlock actuator activate?
