Thread: V8 Conversion
Old 08-22-2015, 06:59 AM   #14
BoxsterLS376
Originally Posted by martsink View Post
Today I started the engine for the first time. Ran into a couple of issues with the ignition and fuel pump. I had to jump the starter cable relay in order for it to crank. At this point I'm not really sure what the problem is, but I'm guessing it has to do with the immobilizer. The car came with no DME, so I had to purchase a matching key, immobilizer and DME.
The fuel relay also didn't switch, so I had to jump it. I'm thinking about just running it from another relay that is triggered by ignition-on wire, unless someone has a simple solution for the existing relay.
First off, killer job man, motor sounds great! I know it's not easy and I think you had a bit of a bigger hill to climb then I did~ Go have a beer
For your starter problem I think you're right, those immobilizers are a pain in the ass and we could never get them working at my old shop and usually ended up sending the cars to the stealership for programming even though we had a factory Porsche PST computer.
Regarding the fuel relay I believe there is an easy solution for this, but it's early and I'm gonna have to put my thinking cap on... All of my notes and paperwork are at the shop but just took a quick look at the car to jog the brain. I have the GM fuel pump lead connected directly into the Porsche harness in the back of the car to a Yellow/White wire which I know leads to the relay panel in the drivers footwell... this is where we get fuzzy and you should rely on the wiring diagrams... I pulled down the relay panel and was basically able to wire around the issue there, pretty sure the fuel pump is looking for a ground signal and the GM ECU is providing a power signal so you have to do some trickery and wire around 1 relay I believe. I'll check my notes on Monday and give you more details if you need but it can definitely be done.
Good job man~
J
BoxsterLS376 is offline   Reply With Quote
