I noticed I was running a bit warm and decided to test everything to determine the problem. I tested the fans by turning on the AC and both fans worked. Pulled the bumper and cleaned out the radiators (they weren't too bad). I changed the water pump, thermostat, and coolant. And I burped the coolant for an extraordinary amount of time. It was during this time that I got around to the front of the car with the bumper still off and I noticed one of the fans wasn't running. Kicked on the AC and they both kicked on at high speed.
I'm still undecided if I'm mad that I changed everything else or not. It was probably due anyway.
