Old 08-22-2015, 04:26 AM   #1
Jamesp
Beginner
Jamesp's Avatar
I've done mine 3 times now, and I think I have a working solution that I will use next time.
400 grit wet/dry paper - wet sand with lots of water
then
1500 grit wet sand - lots of water
then
2000 grit wet sand- lots of water
then
plastic polish (from a turtle wax polishing kit)
then
toothpaste
then
prime with turtle wax polishing kit primer
then
seal with turtle wax polishing kit sealer
The sandpaper greatly speeds things up.
I did one headlight with the toothpaste and frankly did it half a$$ed as it didn't seem to be doing much of anything.
Skipped the toothpaste on the other. The result is they look the same, and quite good in the daylight.
At night with the lights on it is strikingly evident where the toothpaste was used or not. With toothpaste the lens is clear with the lights on, without toothpaste there are so many micro scratches the lens looks frosted at night with the lights on. Oh well, I'll get it next time.
2003 S manual
