How's your idle? My idle started to get worse and worse because I had a bad oil separator which was leaking a tremedous amount of oil into the throttle body and intake system. I would get misfire codes and what have you. I swapped the separator and cleaned out the throttle. Runs perfect now, and no more white smoke. Do a search on WHITE smoke. You should see a post where I uploaded some pictures.
