Old 08-21-2015, 12:43 PM   #2004
Smallblock454
Have a rattling sound from the front left wheel when driving slow over bumps and cobblestones and the car is warmed up.
Jacked the left side upm removed the front left trailing arm (OEM manufacturer = TRW Automotive) and inspected it. No play. Opened the rubber seals by remooving the circle copper steel clips. Was a little tricky - especally to bring them back on wtihsout doing any damage to the rubber. There was grey grease in it, but not much. Added a some special grease i had from the rear axle boots repair and assembled everything.
Well 2 hours without success. Still rattles when the car is warmed up. Next thing to inspect will be the linkages. But i need a lift for that, so both front wheels are fully relieved.
Regards
Markus
