Old 08-21-2015, 10:52 AM   #12
soxfan1966
Most aftermarket DRLs operate in the way you describe using a switchback controller. Not sure why his don't...
I am using a relay that connects to the battery and has a yellow wire which you can connect to a headlight feed to make the DRL's go off when the headlights come on (I did not connect this).
The + and - wires for the DRL's are connected to that relay. Then there is another yellow wire on the DRL itself which I connected to the turn signal to activate the yellow DRL lights. I believe I have mine wired correctly, but its possible I have something amiss. Or it could just be the way DRLs I have work and different types would function as you are looking for ...
soxfan1966 is offline   Reply With Quote
