Old 08-21-2015, 09:29 AM   #10
soxfan1966
Do you mean just a white DRL without the yellow like mine has? That may be a feature of the actual DRL you purchase either way as opposed to something you can wire in generically - so if the ones I have completely shut off the white and only showed the yellow, that is more what you are looking for (or if there was no yellow then just shut the white DRL off the entire turn signal phase?
When I looked on Ebay there were tons of different DRLs so I suspect you could find one that worked like you wanted ...
soxfan1966 is offline   Reply With Quote
